Group: DynoMotion Message: 5942 From: Adrian Balan Date: 11/1/2012
Subject: e-mail format issue
Attachments :
    All the e-mails I get from you through DynoMotion@yahoogroups.com have these strange characters. Do you have a special character setup for your keyboard? Have somebody else face the same issue? What can be wrong?
    > --- In DynoMotion@yahoogroups.com, Tom Kerekes <tk@> wrote:>> Hi Cees,> > I'm not sure how that is supposed to work in Mach3.  Do know where any information on Mach3 and THC is?> > But most likely that was handled by the Mach3 Parallel Port Driver and will need to be replaced by a C Program in KFLOP to watch the up/down signals and jog up and down when it sees the up/down inputs.  You will need to add this into a loop that runs continuously at the end of your Init.c (or whatever yours is called) program.> > > What isn't clear to me is how you enter and exit the THC mode vs normal Z motion mode.> > To be able to move the Z axis independently in KFLOP it must be removed from the coordinated motion system.> DefineCoordSystem(0,1,-1,1);  // Remove Z from the Coordinate System> vs> DefineCoordSystem(0,1,2,-1);  // Keep Z in the Coordinate System>  > > Coincidentally someone from the Ukraine just asked me the same question (within the hour)
    > but he is using KMotionCNC.  He came up with:> > for(;;)> {> WaitNextTimeSlice();> > if (ReadBit(0))                                                             // if plasma is ON?> {>  if (ReadBit(6))                                                     //Up?> {> Delay_sec(1.0);// Delay for error filter> Jog(2,10000);          // Axis Z move UP> while (!ReadBit(6)) ; > Jog(2,0);     > while (!CheckDone(2))  ;  > > }> else if (ReadBit(7))                                     //DOWN?> {> Delay_sec(1.0);//Delay.> Jog(2,-10000);          // Axis Z move DOWN> while (!ReadBit(7)) ; > Jog(2,0);     > while (!CheckDone(2))  ;  > > }> }> > > Seems to me the delays are excessive
    > and maybe in the wrong place, but it should be a start.> > Regards> TK> > From: zeeschuim atmolgers@> To: DynoMotion@yahoogroups.com > Sent: Wednesday, October 31, 2012 8:30 AM> Subject: [DynoMotion] torch height control in Mach> >   > HiPlasma table on Mach3I am using a Hypertherm with a torch heigt control unit what give 3 ouputsignals torch on, torch up, torch down, these signals are coupled on the Kanalog JP15 opto input terminals, in mach3 they are in ports & pins inputs: THC on: port2 input pin 13, THC up: port2 input pin 14 and THC down: port2 input pin 15.So far so good I can see they are working in the Mach3 diagnose screen.But there is no up and down movement of the Z axe.Do I need to write something for notifying the Kflop?thanks,Cees>
    Adrian
    Group: DynoMotion Message: 5943 From: Lee Studley Date: 11/1/2012
    Subject: Re: e-mail format issue
    Adrian
    Group: DynoMotion Message: 5944 From: studleylee Date: 11/1/2012
    Hi Adrian,
    It looks like an UTF-8 encoding problem somewhere.
    Not sure what client for email or browser you are using, but check to see if they are set to use "Western European (ISO)" rather than UTF.
    for encoding. Should be in the settings or options somewhere.
    -Lee
    --- In DynoMotion@yahoogroups.com, "Adrian Balan" <adrian@...> wrote:
    > Hi Tom,
    > <mailto:DynoMotion%40yahoogroups.com> have these strange characters. Do you
    > > --- In DynoMotion@yahoogroups.com <mailto:DynoMotion%40yahoogroups.com> ,
    > WaitNextTimeSlice();> > if (ReadBit(0))       ÂÂ
    >               ÂÂ
    > (ReadBit(6))             ÂÂ
    >              //Up?> {>
    > Delay_sec(1.0);// Delay for error filter> Jog(2,10000);    ÂÂ
    > while (!CheckDone(2))  ;  > > }> else if (ReadBit(7))   ÂÂ
    >               ÂÂ
    > //DOWN?> {> Delay_sec(1.0);//Delay.> Jog(2,-10000);     ÂÂ
    > excessive
    > <mailto:DynoMotion%40yahoogroups.com> > Sent: Wednesday, October 31, 2012
    > Regards,
    > Adrian
    Group: DynoMotion Message: 5948 From: Tom Kerekes Date: 11/1/2012
    Hi Adrian,
    That drives me crazy also and I don't understand it.  It seems like an end-of-paragraph html tag gets mis-interpreted.  I see it is a common problem in many forums/emails.
    I'll try Lee's suggestion and try forcing Western - W Europe (Windows-1252) encoding on my replies to see if that helps.
    This is a test.
    Group: DynoMotion Message: 5949 From: Michael Rosenfield Date: 11/1/2012
    I get them, too.
    Can you elaborate on the settings, and where they might be?
    Are you saying they should be UTF?
    I couldn't find anything obvious in IE9 settings.
    Michael Rosenfield
    Group: DynoMotion Message: 5950 From: Lee Studley Date: 11/1/2012
    Hmm, I've decided IE exploder itself is a bug. The fix is to use FireFox. I couldn't find a settings fix for
    IE.
    On 11/1/2012 7:03 PM, Michael Rosenfield wrote:
    I get them, too.
    Group: DynoMotion Message: 5953 From: Tom Kerekes Date: 11/2/2012
    In IE9 I found right click on a web page allows changing the encoding.  In another version it was under the "page" menu.  Also my web mail allows selecting the encoding for each email I receive.  But none of it makes sense to me.  I will try to switch to Firefox to see if that helps.  I use a bunch of different computers and devices.  I selected this email as UTF-8 before replying in FireFox.
